TwinTurbo.NET: Nissan 300ZX forum - For the VC bolts -- on the exhaust covers I went with
Subject For the VC bolts -- on the exhaust covers I went with
Posted by jzack on April 19, 2008 at 12:32 PM
  This message has been viewed 110 times.
In Reply To 2 steps forward, 4 back. Need some help on VTC, and wiring. posted by 5280Z_nightstalker on April 19, 2008 at 11:54 AM
Message stainless steel hex bolts and lock washers. Stuck with the orginal bolts on the intakes -- wanted them to fit correctly with the nylon (crush) washer. Those intake VC bolts are only under lite torque, so it's pretty hard to strip them out.
Should also plan to replace those nylon washers when you do this job...
FYI -- Hopefully you know the trick about applying extra liquid gasket to the exhaust VC inside corners? If not - I can explain further...
